- Messages
- 5,171
Hi. I am in need of a 700mm x 1500 single rad preferably without fins!
Cheers
Cheers
Discuss Single panel radiators without fins in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Why without fins?Hi. I am in need of a 700mm x 1500 single rad preferably without fins!
Cheers
Myson Premier HE range are the closest I know of to the sizes you want. Stelrad Compact still do a P1 (single panel, no fin rad).Hi. I am in need of a 700mm x 1500 single rad preferably without fins!
Cheers
Why without fins?
Rad extensions?The one there is old barrel top and want as close to straight swop without draining and altering pipe to pipes
Rad extensions?
Or is it too much on show?
Stelrad Compact P1 then.These are fine, it is the depth from the wall that matters. These pipes come up tight to skirting
Plumb Center?Hard to get hold of these if I remember rightly.
Plumb Center?
Reply to Single panel radiators without fins in the Plumbing Jobs | The Job-board area at PlumbersForums.net
