Discuss Single Pipe System Radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Livvid
Hi all,
I have been asked to rerplace some radiators in a old house which has a single pipe radiator system in place.
The Client has purchased his nice shiny radiators and Honeywell TRVs and new lock shields.
Questions
The old radiators are top fed and low return, can the new radiators be bottom fed at each end???!!!!
Is it okay to put the TRV's on as I know these systems are not that efficient as in as the water passes each radiator, it will cool down, will it cause problems in the run by introducing at least 5 TRV's?
What do you charge to replace each radiator, just ball park please, bearing in mind Just rads and TRvs supplied, some pipework will have to be altered for some of the rads so draining down will have to occur.
Thank you in advance.
From my experience it is best to pipe flow to top of rad and return to bottom. If you connect both to bottom the radiators often do not heat right to top. You cannot fit normal TRVs, not sure which you have to use, probably a remote thermostat. In a normal 2 pipe system each rad has it's own supply, so when the TRV shuts down the rad the pipe cools and eventually the TRV opens again. In a one pipe system the pipe stays hot as it is the primary flow to all radiators, so the TRV closes and shuts down the rad. The flow continues around the circuit through the bypass and so the flow pipe stays hot and the TRV does not open again.
With draining down, refilling and some pipework changes I would suggest it would take most of a day to change 5 rads, so a reasonable figure would be a day rate whatever yours is.
You really need to use Trvs suitable for one pipe systems. ie low resistance valves like Danfoss RA-G or Belmont VBG.
You will most likely have problems using std valves.
I have come across single pipe systems where the pipe goes through the rads and not bypassing so if you turn off one rad it stops all rads after that point
Despite me telling a customer that you couldnt polish a turd ,at his insistance I fitted 7 new rads to a 8 rad one pipe system, I used standard TRVs, the system worked worse than before,no matter how hard I tried to balance it or what speed the pump was on I could only get 4 rads hot at a time.We then went with my original suggestion and I ended up 2 piping it in speed fit to keep time and costs down, it worked really well then, i dont do work for people like that anymore.
So really I should advise the customer to buy TRV's Especially for the job, I know the customer doesnt want the floorboards up and a two pipe system in place.
So can I bottom feed??? Is it best to advise the customer that they may not heat up correctly am I walking into a world of pain if I fit TRvs to this system????
buy manual valves and feed it TBOE if possible, maybe even use swept tees, ive had to do that in the past
My customer didnt want his floor boards up etc, he was a miser.Bottom feeding (lol) the system wont make it that much worse although continental piping, flow top, return bottom does work better than bottom feeding, fire up the system leave it on for an hour, see how poor it is, then when you put in the new rads the customer cant say "it worked fine before you touched it",
continental system? why do you call it that? single pipe has always been TBOE, commercial systems are peiped up like that when 2 pipes
advise your customer properly put the one pipe system in the bin as its **** and convert him to 2 pipe,very good advice off BCG you could catch a cold here
Reply to Single Pipe System Radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
I'm trying to get to grips with a system I have inherited as a new home owner. I know that single pipe systems are crap and should be replaced...
2K
N
Hi! We're looking for a consult for our 1905 built (renovated in 2010) victorian house for the future of our heating system. The house is 2...
Hi All! Bought a house recently, and we have been having the most frustrating issue with a very loud humming noise that intermittently comes and...
2K
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
