Discuss sink waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
can i buy a rod for moving the plug up and down on a pop up stopper on its own or do i need to buy the whole thing ? , i mean the rod with the ball swivel fitting thing that conects from the stopper to the rod for moving the plug up and down , if so were can i get one ta .
Much to my surprise I see you can buy them! Try Googling "Replacement Basin Pop Up Waste Arm Rod"
Eg: https://www.amazon.co.uk/Universal-...t-Basin/dp/B07R1KWBCL/ref=asc_df_B07R1KWBCL/?
I had assumed that the size of the 'ball' would be different between brands, but maybe that's not the case?
OP: if you know the manufacturer of the waste you may find they sell the rod, or set of rods, as a spare part. I see some do.
Otherwise may be easier to replace the whole waste assembly.
Just because someone sells a ‘thing’ , doesn’t mean it’ll solve the problem!
They do differ between manufacturers; some are metal/plastic/nylon, some come with a nylon female cup etc etc.
It may work, and hopefully it does - but no guarantees.
Reply to sink waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
