Discuss Size of inserts for kitchen mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
beesley121
Hi guys,
A customer has a kitchen mixer tap, quarter turn tap and need the innards replacing. I've bough both 1/2" and 3/4" and both don't fit. What's going on? It the same for another customer in have. Are these taps a direct size or are the glands I've bought cheap rubbish
help appreciated
There are thousands of different quarter turn innards out there
Best bet is to find the tap manfacture and get them from there, if it is a branded tap then it might still be in warranty :)
It's not the length of the cartridge or anything like that, that doesn't fit.
its the size of the hole in the tap with the thread (technical term). As said, I've bought 1/2" and 3/4" replacements but 1/2" is too small, 3/4" is too big
I would of thought they were pretty standard thread sizes
You need to count the number of teeth on the spline as they differ in number
Sorry mate, it's got both thing to do with the hand for the tap, it's the hole that is in the main body that the cartridge goes into
not unless you mean that the number of splines does have an impact on the overall size of the cartridge! I thought that was to do with it fitting the handle
Plumbfix sell a tap reviver kit which contains 2no levers,2no 1/4 turn cartridges and 2no reducing bushes.These are the bushes you need size is in between 1/2 and 3/4 the complete kit is about £12 hope this helps..brum
Reply to Size of inserts for kitchen mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
