Discuss sleeve for plastic barrier pipe in screed ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, i need to put some rad pipes in for our extension, i was going to use JG speed fit.
for a sleeve i was going to buy a few lengths of 25mm plastic conduit and some sweeping bends so there is no joins in the floor.
any probs with that ?
thanks
You could use pipe in pipe if you want. It is a sleeved pipe if you don't know.
Hep do it in red or blue corugated plastic sleeved
Reply to sleeve for plastic barrier pipe in screed ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
