Discuss Slow draining bath tub in new houseS in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Z
zouganelis
Hi folks,
I have bought a new house a year ago from a developer and besides the usual minor issues you get with new houses, this one has been troubling me for some time. The plumbers who fitted the bathroom had another look when I complained repeatedly about the slow draining of the bath tub, asking them whether it is a venting issue. Unfortunately when they turned up my wifewas only at home so I couldn't see for myself. Tonight after taking a shower and watching the water level rising once again by 1.5 to 2 inches while taking a quick shower, I thought I should have a look for myself and took some photos. I am not a plumbing expert but I was expecting a venting oipe somewhere after the trap, which doesn't look right to me. Can you tell from the pictures if the work has been done professionally or whether it is a bodge?
Many thanks in advance.
not vent required on the trap, the pipework could do with more support. I would remove the trap first to see if its blocked, if that clear then look at the pipe and its connection into the soil pipe as a possible point of a blockage.
very common to find plaster and saw dust blocking traps and waste pipes on new build properties.
perhaps the boss on the stack not bored out properly and right size
Thank you both for your input. I will check the trap for debris and if nothing is found I will follow the pipe to the boss and see whether there is anything that looks odd there. In any case, would an extra vent after the trap help at all?
doubt it in your case.
do what you suggest, i think you will find something there.
Reply to Slow draining bath tub in new houseS in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
Hi, I have a bath tub in my apartment that is draining very slowly. It does finally drain but only after about 12-15+ minutes. After trying...
Hello everyone. New to the forum and looking for assistance / advice. I live in a rented house with a not very co-operative landlord. I have just...
Hi, I live in a house that is 20yr old. There is a single soil stack running from the top floor (of three) through the first floor bathroom and...
