Discuss Smart thermostat with zoned multifuel heating system in the Plumbing Zone area at PlumbersForums.net
U
Unregistered
Hi all,
I have just stumbled across your forum while trying to find a solution to my heating system control problem. I hope someone can offer a small bit of advice - it would be very much appreciated.
We are trying to install a new central heating system. It will be a fed by a combination of a Grant oil boiler, Stove with a back boiler and solar panels. All of these inputs are linked into a Systemlink manifold with a heat genie for the stove. There are four output zones, three space and one for water heat. All good so far. However, we have reached the point where the plumber and electrician are trying to install the Nest learning thermostats and they have now decided that the Nest system will not work with our setup.
I would really appreciate if anyone has had any experience in getting a Nest thermostat or other similar smart thermostat to work in a set up such as this. I believe this should be possible but Nest are not being very helpful.
Any advice much appreciated,
Thanks,
Aimee
1st piece of advice is to register and repost your question then we have a name to reply to.
Aimee
Where are you from
Your system sounds like your in northern/Southern Ireland
Reply to Smart thermostat with zoned multifuel heating system in the Plumbing Zone area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
