Discuss soft jaw grips/similar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
helpsy
Where is the best place to get a decent pair of soft jaw grips please?
Never seen them in my local parts centre or City’s a plumbing mate. (Sorry) I’m sure @ShaunCorbs will pop Along shortly with a link for a supplier.:p:p
Depends what your going to be using them for, if your only going to be using them on spanner flats / nuts then go for the knipex pliers wrench
If your going to be using / wanting the grip function then go with the soft jaw ones but they won't grip like normal grips
Also I wouldn't go with anything else other than knipex I've got a set 10+ years and there still going strong
Knipex 86 03 300 Pliers Wrench Adjustable Spanner 300mm | eBay
Knipex 81 11 250 Soft Jaw Plastic Traps Tube Fittings Connector Gripping Pliers | eBay
For chrome nuts and shower items that are round
It will have to be the more rounded shaped soft grips then. I suppose you could have that and a Knipex parallel jaw wrench.
Plumb center were once doing the Knipex parallel wrench at good price, that was posted about on here. Otherwise shop around or try online to avoid high cost.
Note that the Knipex is made in various sizes. I have the 250mm I think, and it has max opening of jaws of 2 and a 1/4"
Reply to soft jaw grips/similar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
