Discuss soft jaw grips/similar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
helpsy
Where is the best place to get a decent pair of soft jaw grips please?
Never seen them in my local parts centre or City’s a plumbing mate. (Sorry) I’m sure @ShaunCorbs will pop Along shortly with a link for a supplier.:p:p
Depends what your going to be using them for, if your only going to be using them on spanner flats / nuts then go for the knipex pliers wrench
If your going to be using / wanting the grip function then go with the soft jaw ones but they won't grip like normal grips
Also I wouldn't go with anything else other than knipex I've got a set 10+ years and there still going strong
Knipex 86 03 300 Pliers Wrench Adjustable Spanner 300mm | eBay
Knipex 81 11 250 Soft Jaw Plastic Traps Tube Fittings Connector Gripping Pliers | eBay
For chrome nuts and shower items that are round
It will have to be the more rounded shaped soft grips then. I suppose you could have that and a Knipex parallel jaw wrench.
Plumb center were once doing the Knipex parallel wrench at good price, that was posted about on here. Otherwise shop around or try online to avoid high cost.
Note that the Knipex is made in various sizes. I have the 250mm I think, and it has max opening of jaws of 2 and a 1/4"
Reply to soft jaw grips/similar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
How it best to install pipework to best avoid airlocks with gravity hot water. Install level or slightly down hill in direction of flow? Thanks
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
