Discuss Soil Boss Connection - Push Fit or Solvent?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
marshr02
Looking for help.
Using Floplast fittings. I have to make two connections to my soil pipe; one is a 50mm pipe under the floorboards, the other is 32mm within easy accessible carcassing.
I see Floplast do a rubber bung thingy for stuffing into the Boss's 50mm socket. Also a solvent weld reducer.
The rubber bung doesn't look too clever, yet I want to make something that can easily be adapted without pulling apart too much.
In the past I've used a solvent adaptor (for the boss) with a ring-seal socket for the waste pipe. But floplast don't seem to do these..
Interested in what others do?
Cheers
Sort of use whatever the local plumbing merchant has in at the time. I prefer solvent weld but if there's only push fit available I'm not going to waste time going to another outlet.
Thanks for the reply.
If we assume the local merchant has everything stocked (yes, I know, it's not often that way)...:
I prefer solvent weld as well, but I presumed the waste branch would benefit from an expansion joint, and what better place to put it then at the boss. That way any future alterations to the branch don't require messing with the stack. I've used solvent weld adaptors with a ring seal on the other end - seems perfect. BUT Floplast just have a rubber bung that I wouldn't trust to have under the floorboards.
Guess I'm just asking if other people have been here before.
why do you have to use flowplast? go to grahams , plumb centre , plumbline the list goes on and get solvent weld for under floors if you are concerned about it.
I dont use flow plast so wont comment on that but all the materials such as the rubber connector you are talking about are made to go in the boss so should not leak
and also are you useing the flowplast to save money? because if your customer puts nice tiles down on the floor and then 6 months down the line it starts to leak then it will cost you more money and your reputation aswell maybe.
I never use push fit waste under floor or even multi fits (unless I have to) I only use solvent fittings infact the only waste fittings i use is solvent weld unless connecting on to old copper wastes etc were you have to use a multi fit
Didn't want to mix manufacturers in case of slight problems with pipe diameters? The soil stack just fitted is Floplast, so the boss is floplast. Is the boss inside diameter standard? In which case all I would need to do is source another PVC based adaptor; solvent weld into the boss with a ring-seal to accepting solvent weld 40 waste...
Cheers
I'm DIYing (experienced), not in the trade. I have asked 3 plumbers to quote to install my stack, and placed a note on this website, but no takers at all?!!
The stack is push-fit, which I guess is pretty standard. The branch pipework is to be solvent weld for the reasons you quote. Just aware that the bath run is just shy of 3m so could do with expansion joint somewhere?
Reply to Soil Boss Connection - Push Fit or Solvent?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
