Discuss Soil pipe through tile hung wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MOSSEP
I need to take a soil pipe through a vertical tile hung gable wall at my own house, does anyone know the best way of sealing it and making a good job of cutting the tiles? I wonder if there is a flashing of some sort on the market that might fit? Has anyone had to do this, if so what did you do?
pipesnugg?
Cheers,
That McAlpine flashing from tool station might do the job, Ive also seen a lead version thats similar. I had hoped to carefully core drill the tiles in situ but I cant see it ending too well. The pipesnug looks good, but I'd imagine its only effective on a brick wall?
I used a lead flat roof slate when I had to do this, it worked well and was easy to use. Could probably do your own out of lead if confident, but this was much easier!
Personally I striped off tiles for a good sized margin around work area as only had two spares and I thought they might start jumping off with the vibration. Just go steady and you’ll be fine.
Reply to Soil pipe through tile hung wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
Hi, I live in a house that is 20yr old. There is a single soil stack running from the top floor (of three) through the first floor bathroom and...
Hi guys, I've had a search and couldn't find anything related. Installing a wall mounted toilet, unfortunately didn't know this when I put the...
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet...
