Discuss Soil Pipe Vent Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
In my new build I have 4 soil pipes that pop up at various walls on the ground floor. All pipes connect into a single pipe for the sewer.
One pipe will connect to a toilet on the first floor and also connect to the shower and sink waste. Another will connect for kitchen water waste and the others for future provisions.
For building regulations I understand that I need a vent.
My question: Do I need to vent in only one place - i.e. near the toilet or do I need to vent all pipes?
For the vent, how high does it need to vent?
Thanks,
Dave
The one outside venting to atmosphere has to be a minimum of 900mm above any opening to the building ie window, dormer or vent etc.
Isn't that with a Durgo on thought it was 1.2m for natural ?
OK, so I'll vent the one connected to the toilet (which is at a high point).
Regarding the Durgos, I understand they have to be placed on a vertical connection. Do they have to be a certain height and presumably these are OK to add on the first and ground floor?
Dave
The original distance was three foot above any opening into a building. I still use that and I wish the rest of the world would stick to what's in my head lol.
Minimum 3ft (900mm) in my head too. I still stick to that as well. Makes me cringe how many times I see a low level hopper T'd into a stack or a gutter downpipe put into a stack effectively making the height of the vent void and now venting at gutter level inches away from a bedroom window or venting out of the hopper at the side of a kitchen door etc..
To really get technical about the situation, you need to provide a plan of the drain runs, distances and pipe sizes.
There are regulations available about venting of soil pipes available.
As long as you follow the regulations, you shouldn't have a problem
My understanding of AAV's were to be fixture based
eg: You have a basin installed to a stack and you can't get the allowed distance from the vented stack to the fixture location.
So without running a vent from the fixture to atmosphere you could install an AAV.
I would never install an AAV at the top of a stack or on a branch drain that is picking up several fixtures.
Reply to Soil Pipe Vent Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The soil pipe from my bathroom passes through the outside wall and into the roofspace above the adjacent single storey kitchen before dropping...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi, I'm wondering if this is allowed or will work in the UK. We currently have all our waste water connecting to a single vented stack. The pipes...
Hi all, I have an old toilet on the top floor (to be removed) which empties into an outdoor vertical SVP and into the ground. The pipe is...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
