Discuss Solar Thermal installed - does this look right? in the Renewables area at PlumbersForums.net
Ok thanks, I did have a cylinder before so not sure whether the old valve was in the same location, its not working anyway because he hasnt wired it up properly lolFor draining and flushing the solar system
Hi , so just to get my head around, the valve is too close to the tundish and should be 600mm away?Cylinder install is wrong the transition to d2 should have a tundish maximum 600mm away from the valve
Reply to Solar Thermal installed - does this look right? in the Renewables area at PlumbersForums.net
