Discuss solder snots on pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bar looking unsightly are solder snots ruining down the pipe from the above fitting a problem. Guy I work with does this. Looks bad but is on a first fix so underfloor pipework that will never be seen.
simple get a file 5 seconds and done
Thanks its the fittings were the joint is horizontal he is feeding the solder in to ends up all down the pipe with no attempt to brush off.etc
Probably loading the fittings a bit if they're not going to be accessible
I wouldn't worry about underfloor pipework, as long as it's leak free it's all good. With visible pipework I always clean the pipe with my flux brush to brush off any excess solder while it's still hot enough and then when it's cooler clean off the excess flux with a rag
Then when it's all done a quick buff with wire wool and it looks mint.
If you've got a snots on the pipe its not a problem if its not seen, although a wet rag and while the pipe straight away should remove them or re heat the snot and whipw it off with a wet rag
Far worse than snots are solder icicles. No idea how they form but are lethal to fingers of an unprepared plumber.
If it is a Yorkshire fitting and solder runs down the pipe on a vertical fitting, then it is wrong because the solder has basically run out of the fitting.
I can't see why plumbers leave solder running down pipes, but if a hidden joint has been carefully end fed solder and a slight drip of solder is missed in wiping the joint I wouldn't worry about it if the joint inside is fully soldered.
If a plumber can't wipe any excess solder to tidy and complete a soldered joint, I don't think they are worth employing.
Reply to solder snots on pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
