Discuss Soldering mat?????????? in the Plumbing Tools area at PlumbersForums.net
Scott_D
Subscribed
What’s the best soldering mat / heat proof mat available?
Cheap bes ones and staple 2 together ends up around £3 lasts over a month
Absolutely the best way by far and that's why I stock the workshop with cheap BES mats as they take a hammering teaching schoolkids and apprentices to solder. £1.54 each if you buy 20+. Used in pairs like Shaun says. £3 per mat, last quite a while and nearly as long as a single posh mat costing £25 but you've got ten double mats to last you ages for £30.
A heat mat is basically a protective heat shield thats flexable and can be placed behind pipe joints before you solder them. I have found the rothenberger ones, although not the cheapest have served well and protect woodwork from discolouring due to heat. Tread carefully when near wires, if you really have no options then I use steel plate behind the heat mat for added protection.
I don’t think I have ever bought one. Tend to use plasterboard, old tiles, quarry tile or non asbestos cement board. Having a good blow lamp with nice tight flame helps. Or make the tricky bits up away from immediate job Now I have some pull extruded glass reinforced polymer sheets which resists even map gas up to about 1600c Centralheatking
Monument ones I find last a bit longer, the paded rathernberger ones go very fast.
Best way to save your mat is to use blue bottled gas the yellow mapp just destroys any mat.
Also because they never last long price is quite important if you can buy two for price of one mat it effectively lasts twice as long. Im getting monument ones at £9 on ebay
I can remember people using bits of roofing sheet, and never questioned what it was made from. The corrugation forming a snug shield round the pipe, just no good in really tight spaces.
set asbestos cracks and can explode when even moderately heated though
In the days of pilot lights and no PCB's in boilers we just got the job done, life was so much simpler and I am convinced that the customers were also happier, now they get error codes and think they are being taken for a ride!
yep, give me a Baxi Bermuda any day.
Piece of plywood wrapped in ptfe.
Whatever you use for a heat shield DONT use a bit of sheet lead. Knew a plumber who did. Half way through heating the lead just fell to the floor and yes the flame burnt what the lead was (limited) shielding!!!
Reply to Soldering mat?????????? in the Plumbing Tools area at PlumbersForums.net
Hello to everyone.Im a newbie here. plumbing & heating+GSR engineer.
