Discuss Solenoid valve magnet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for a solenoid valve magnet for checking solenoids.
I see Danfoss do one but......£45 !!!!!
Is there a cheaper version available, or do folk just use a 'normal' magnet?
45 notes seems a bit steep.
I see Danfoss do one but....£45 !!!!!
Multi-meter!! + Screw driver.
Never use anything else!
Pray tell, what does this device tell you ?
I'm not one for gadgets to be honest but I am intrigued
Goes on in place of the coil and actuates the solenoid by permanent magnet.
I see them used by fridge engineers on commercial plant but don't see the need on Gas equipment of any kind.
Oh I see. Sounds a bit dodgy to me.
I can't think why you would want one on Gas and Oil would be pointless.
Unless I am missing the point behind needing it?
Is it for keeping them open whilst you do something like replace the solenoid ?
To the OP......What do you need it for?
Surely all you would need is a brand new solenoid?
And you could link to a solenoid live (inside control box) if you needed to power it, although not sure why you would need to.
While on the subject, - Do not put power to a solenoid and leave it, because it will melt and set fire or damage surroundings! The solenoid needs to always cool while attached to the solenoid valve stem, which absorbs the heat it generates.
I use a screwdriver down the middle of solenoids to test the pull and sometimes I just hold a screwdriver tip to top of solenoid while it is on oil pump, to feel the magnetic pull.
Reply to Solenoid valve magnet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
