Discuss Solvent weld question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JCplumb
Hi chaps,
Had a job last week where I had to convert from solvent weld waste pipe to 40mm compression/pushfit waste pipe.
The customer is a landlord and wants everything as cheap as possible, I didn't have much of a run of pipe to work with so ended up solvent-welding a piece of 40mm polypropelene pipe over about 4 inches of the solvent weld. After about 15 minutes it was still a bit loose but after an hour it was solid. I didn't have room for an adaptor as it was tight up against some other pipework.
Question is:
Will this hold?
No. Solvent glue only works on ABS or Mupvc. You need a multifit fitting.
Polyprop doesnt sovent weld. You need to get a SW to push fit converter fitting
Thanks for the advice guys, looks like I'll have to play Tetris again in this bathroom. There's no access to the back of the bath and only about 2 inches between the bath/toilet/ped :(
Expansion and contraction of the pipe when hot water is run through it will cause the solvent to eventually fail as there is no chemical bond being formed as what happens on solvent weld systems.
This is the reason I carry untold amounts of waste fittings at all times, and keep them topped up, you may have gotten away with CT-1 in fact you probably will have but not ideal. Comp coupler or solvent weld better of course though.
Reply to Solvent weld question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Everyone, Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside...
1K
Does anyone have a preference to use solvent weld or compression fittings for waste pipes?
8K
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Morning All, Just after some advice as I have been asked to plumb in a sink and washing machine waste for a new kitchenette. The other side of the...
2K
