Currently reading:
Sounds like water hammer after pump over run
Discuss Sounds like water hammer after pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sammyt
Hi
Ive got a problem I've not come across before.
when heating call to the boiler switches off the circulating pump runs as it should for aprox 3 minutes, the second the pump stops there is a loud bang or 2 from the airing cupboard/loft.
Gravity system, BRitish gas install around 3 years ago but person only moved in recently.
thanks
Thermal shock? Three port valve slamming shut? I had the latter last week the three port slammed shut so hard it could be heard all over the house valve was three weeks old
Doesn't the 3port adjust as soon as the call for heat stops, where's the pump continues to run for a couple of minutes?
Reply to Sounds like water hammer after pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
