Discuss Square tap holes... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
So when replacing taps on these for basins what do you use as some new taps don't even cover the holes. I have seen most of them stuffed with plumbers mait but not really keen on that. There has to be a better way?
Plastic washer
If the taps don't cover the holes on the top then different taps, and just use a big plastic washer on the bottom
I like to discard the under tap washers supplied with the taps and replace them with Deva Dat001 anti spin washers and pop a half inch poly washer underneath. The washers cost ÂŁ26 for 200 from amazon. The rubber is much thicker and wider. Some of the washer also fits into the square hole.
Nice
Reply to Square tap holes... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
