Discuss Squealing kitchen tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm hoping someone may be able to help!
We are currently getting a loud squealing from our kitchen hot tap whenever the shower is used upstairs. If you turn the tap on it will stop the squealing, however it then will have a constant trickle/slow stream of water from the tap.
It doesn't cause any problems at any other times.
I've included a picture of the tap if that helps at all.
Thanks a lot!
Yes if you can turn the supply to the tap off and have basic tools e.g. Adjustable spanner or grips etc
When you get the cartridge out take it to a merchants to match it , there's plenty variants
Reply to Squealing kitchen tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of...
Hi Anyone know of a pull out kitchen tap that has decent pressure? I have had low pressure from this tap for a number of years and it's not...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
