Discuss stopcock being noisy in the USA area at PlumbersForums.net
My stopcock is located in upstairs airing cupboard. Is it normal to hear water rushing through the pipes. Tried turning it down to no avail
It's not an emergency, I would try not to make it one and leave well alone at the moment. I assume the noise stops when everyone is in bed and stops using the water, if so, obey the prime directive, "if it ain't broke"
In the present lockdown I would be leaving that old stop tap alone and put an old pillow over the pipe you will kick yourself if it starts dripping etc. even if you know how to re pack it getting parts is problematic.
Centralheatking
Reply to stopcock being noisy in the USA area at PlumbersForums.net
Hey all, Looking for some advice. My mother recently had her boiler changed but in the process the water had to be turned on and off as you would...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hi, as you can see pictured I have a stopcock without a packing gland. Over the past few days my cistern inlet was suffering from an airlock and...
