Discuss Strange Radiator Valve Screw in the DIY Plumbing Forum area at PlumbersForums.net
I need to turn on a radiator and want to remove the valve top to put a spanner on it as it as it is stiff,
however the screw holding it on looks like a security screw as it has two holes in it.
Has anyone seen these before?
Yep if you get a flat headed screwdriver in / on one slot and tap it should go round etc
Was it Hoval or Ideal valves? Used to have loads of those knocking around: rectangular piece of steel with a couple of square holes in and two prongs off each end. Prongs unscrew the lockshield valve cap, square holes for adjusting/shutting the valve. Simples!
Reply to Strange Radiator Valve Screw in the DIY Plumbing Forum area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
