Discuss strap on boss help please in the USA area at PlumbersForums.net
I need to add a new strap on boss to an internal soil stack. Problem is the soil pipe is tight into a corner and I can’t get the strap connections around it.
What alternatives are there?
Stupid question maybe but if I cut the connections off I can get the rest of the strap round, would cable ties be enough to hold it? Or just the solvent?
Another alternative, this is for a 50mm shower waste, however I do have a basin waste I can T into a few inches from the soil stack (after a 4m 50mm run). However the basin waste is a smaller size, it’s old and seems to be between a 32mm and 40mm??
Thank you!
Possibly, thank you. I can get one and see!
The 50mm option is out of stock near me. I can get a 40mm one - is it ok to step down the waste size for the last few inches of pipe?
[automerge]1596361833[/automerge]
My pipe run would be a foot or so of 40mm from the shower waste, stepped up to 50mm for the rest of the run and then down to 40mm again for the last few inches to the stack. It has an air vent at the start of the run from the shower tray.
There are other merchants, stepping it down from 50 to 40mm isn't recommended, especially on a shower waste where the hair, grease and skin etc. has had chance to cool down and congeal by the time it gets to that point in the waste run.
It's not to regs but you might get away with it, are you a gambler? :)
Reply to strap on boss help please in the USA area at PlumbersForums.net
Trying to connect up new 40mm waste into the old soil stack (which would be an absolute pain to remove), it's all Osma pipe, from the 70s...
1K
G
Morning everyone. Got an issue with an internal soil stack boss strap failure. The boss strap had been sealed originally with silicon which has...
1K
Hi, I have an opening on the 'manifold' (I think that's what its called) on my soil pipe. It appears to be a non-standard size - about 51mm...
Hello, Renovating downstairs bathroom, we have changed the layout and I just wanted to confirm if what I want to do is appropriate. I want to...
Hello. This is my first ever post asking for help. I had a bathroom renovation done early this year which I did myself. I wanted to have a low...
