Discuss Stripped packing nut in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sallan
Hi -
Looking for some advice, I am trying to replace a washer in a faucet to fix a drip, and the outside of the packing nut has been stripped pretty badly. Any suggestions?
I have tried a pair of Channel Lock pliers, but that seems to be making it worse! Should I just replace the whole lot?
Many thanks in advance ~
You do'nt have to undo the gland packing nut to replace tap washer,you remove the complete tap head from its body
I may have used the wrong term, sorry, clearly a noob.
I am replacing the washer on a tap. I can access the washer on the other tap just fine (by removing the assembly using the packing nut).
Suffice it to say, I am looking for advice on dealing with a stripped nut...
I am Canadian actually. Your foreigner sensors are quite acute, but need a slight adjustment. I hear this is a common problem for you Welsh people. :)
Reply to Stripped packing nut in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Hi. I have a kitchen mixer tap unit with older washer type inserts which has a dripping cold side. I have a pair of replacement ceramic inserts to...
Hi, my tap is dripping. It’s not constant. Sometimes if I try that extra tighten it stops but most of time slowly dripping It’s dripping from the...
Deleted member 120897
