The thing is why does it smell like gloss/varnish as opposed to kerosene?...Worse when boiler has fired for c.10 minutes each time. Could it be nozzle that is faulty, namely spray is not sealed?
Discuss Strong gloss/varnish smell from back of oil fired boiler- help needed asap. Live in Mawnan near Falmouth. in the Oil and Solid Fuel Forum area at PlumbersForums.net
Thanks very much. I don't want it leaking into foundations...so difficult to get a local guy here asapA faulty nozzle is common but your problem is not going to be caused by that. It's much more likely a gasket has failed, ie burner gasket, flue seals or chamber door seals. However the smell of gloss/varnish is not a smell I've had a customer complain about to be honest. Perhaps you have a slow leak that has soaked into some skirting board etc and when the boiler is running the heat lost through the casing is vapourising the kerosene and you're getting a combined smell?
Any oil leak needs to be rectified immediately, the damage to the environment and fabric and footings of a building can be huge, I've known some remedial works in that situation to be well over 100k!
Do you have any CO testers? If so I would place one by the boiler.
Without being there it's hard to say what it is and what makes it worse your boiler is a combi and you need it for hot water, otherwise I'd say isolate the fuel at the tank for 24-48 hours and see if you notice a difference.
Reply to Strong gloss/varnish smell from back of oil fired boiler- help needed asap. Live in Mawnan near Falmouth. in the Oil and Solid Fuel Forum area at PlumbersForums.net
