Discuss Strong glue for plastic in the Plumbing Tools area at PlumbersForums.net
I know this is off topic.
However my car petrol door/ cover has come off. It needs gluing back on. I have tried gorilla epoxy glue. But it keeps falling off. It's plastic that I'm trying to glue.
Any help would be grateful.
It’s all in the prep need to clean and sand both surfaces then clean again etc
Surprised Gorilla epoxy doesn't work (contaminated with fuel so give it a proper clean with a solvent?)...still I'd still recommend JB Weld, that has never failed me. Not sure about uxing PVC cement, I suspect you're trying to glue together two different types of plastic with the door and frame.
Reply to Strong glue for plastic in the Plumbing Tools area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
