I did some temp readings on my boiler that is kettling.
would someone be helpful and tell me if it looks like the pump ok or not? also who I should approach getting it fixed/serviced in the Boston area. id like an engineer who can fix rather than replace.
pump setting 2:
0min 22 flow pump running boiler off diff 0
1min boiler on 1min later boiler making low hissing sound
5min 34 diff 9
7min kettling
10min 38 diff 9-10
15min 43 diff 10
20min 46 diff 10
25min 50 diff 11
30min 53 diff 12
35min 57 diff 13
40min 62 diff 14
45min 67 diff 16
50min 71 diff 17-18
last reading just before timer turned off, the boiler stat was about to trip also, roughly 90secs after the 50min reading 73 flow diff 19. so it seems the higher the flow temp goes the bigger the differential. is that normal?
pump setting 2:
5min 34 diff 9
7min kettling
10min 38 diff 9-10
15min 43 diff 10
20min 46 diff 10
25min 50 diff 11
30min 53 diff 12
35min 57 diff 13
40min 62 diff 14
45min 67 diff 16
50min 71 diff 17-18
