- Messages
- 10,619
looked at a job today old neta heat in kitchen and cylinder cupboard abot 15m away with pump and valves in there problem is vent and cold feed are at high and low level to the boiler so not teed in to the airing cupboard (tank is sort of half way between the two)im thinking system boiler but the rads are old and worried about leaking so would have preferred ov but cant see a way to put existing coldfeed and vent into a 2 connection boiler
if i tee cold feed and vent in close to boiler with pump fifteen ft away do you think it would work
