Discuss Suitable replacement for a Planus macerator? in the USA area at PlumbersForums.net
I live in a converted Victorian pub, and our kitchen and downstairs bathroom are at basement level.
Behind the downstairs toilet there’s a (Broysan?) Planus macerator that handles the waste from the toilet, bathroom sink, shower (which is raised), kitchen sink, dishwasher and washing machine. I’m not entirely sure of the pipe work but there’s vertical boxing in the corner of the room that aligns with the boxing in the upstairs bathroom, so presumably the waste travels vertically upwards to the main soil stack.
We moved in in October 2014 so it’s at least seven years old, and to be fair it’s run pretty reliably until the past month (and we probably didn’t descale it for the first two or three years, being uneducated macerator virgins).
A few weeks back I found it running and running and running, so (when descaling made no difference) I popped the fuse out and called a guy. Amid much effing and blinding he did a lot of wet vaccing and cleaning, then put the thing back together. It seemed to run better for a bit, although still not cutting out as quickly as it used to, but there was a bit of leakage a few days back (grey water, thankfully) and today it doesn’t seem to want to cut out.
I don’t know how old the current macerator is, and I don’t know how it was maintained before we moved in, and I know we haven’t been particularly nice to it over the years so I’m tempted to replace it rather than throw good money after bad.
I’d happily buy a Saniflo, but from what I can see they don’t have a unit that simultaneously deals with a full bathroom (albeit not a primary bathroom) but also the grey water from the kitchen.
Any advice on a suitable replacement, and/or a pro that handles south east London? Or some very obvious spare part I need to buy and fit (or pay someone to fit)?
Many thanks
Because of the amount of different water imputs connected I am not aware of a stand alone muncher that you could use and stay within the warranty guidelines so suggest that instead of paying out a large sum of money for a Saniflo you simply replace like for like and find one that looks the same as what you have.
It looks as though there are only three inputs connected to the macerator itself: one on the top from the kitchen, one on the bottom right from the shower and sink and then the W.C.
Does that make a difference?
As long as the new one is identical in pictures to what you have then there will be no need to alter anything.
Reply to Suitable replacement for a Planus macerator? in the USA area at PlumbersForums.net
I’m about to embark on a new listed building restoration project. There are seven bedrooms and three bathrooms, one of which in downstairs so not...
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the...
Hi all - would be really grateful for any advice on an issue I'm having with a macerator. It is connected to a sink, shower and washing machine...
4K
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
I have 2 Saniflo macerators in my flat, the one in the kitchen had to be replaced some time ago and I seem to recall the engineer asked me for...
