Discuss Supporting pipes under floorboards + insulation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Its character buildingYes, but I don't fancy crawling there!
Is there a crawl space under the floor?
Do you have to?I hate doing that.
Only if the pipe runs parallel to it.Screw to the side of the floor joists ?
What did you do with the risk assessment form???
I understand how the strap band works with the insulation-wrapped pipe. But how do you clip a pipe with insulation around? You'll have to remove a small piece to allow for the pipe clip?
Someone needs to invent a long flexible support you can slide under the floorboard, screw to the joists at each end and then slide the pipes onto it. Job done. Basically doing the job of the plasterboard ceiling supporting the pipes that you run under the first floor.
If it's plastic I'll have to do it every 300 mm. It seems there's no other way round screwing something every 300 mm whatever support method I choose.Screw a piece of 2x2 if it’s perpendicular
Reply to Supporting pipes under floorboards + insulation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
