Discuss Surging jet pump not reaching cut off pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I need some help.
Problem: my jet pump fluctuates between 15-35psi and will not build any pressure higher than that. There is a swooshing or surging sound that continually occurs.
Location: it pulls water from a lake to supply the house. Lift is 40ft distance from foot valve to pump is 90ft.
Equipment:
brand new 2 line version of the Franklin electric rm2 jet pump 220v
Brand new Cage/screen, venturi and foot valve
I blocked in the discharge of the pump.
I primed the pump by using a auxiliary plug -in pump plumbed into the top suction line.
I then circulated fluid through and bled the water through a tee on the discharge line for about an hour.
When the pump is off it'll hold the pressure solid so I don't think there are any leaks on the suction line.
The pump continues to swoosh and surges though there's still air in it.
Any advice?
Reply to Surging jet pump not reaching cut off pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
