Discuss Surprisingly, with the fast toilet switch, only the tape is used in the Plumbing Jobs | The Job-board area at PlumbersForums.net
No need for any complicated chemicals or equipment, you can completely clear the toilet with just a roll of tape.
bat-ngo-voi-meo-thong-tac-bon-cau-cuc-nhanh-chi-dung-bang-dinh-thong-bon-cau-7-1511160011-267-width600height334.jpg
There are many simple ways to clean the toilet that you can do yourself, no need to call a steward or fix a complex sink. Along with the method of clearing the toilet bowl, using ice, using vinegar and baking soda, you can also quickly open the toilet with adhesive tape.
It is quite difficult to understand, but actually this method is very simple without much effort, the effect is very unexpected.
First, use a rag to clean the stain, water on the toilet.
Then pick up the tape (note the tape should be thick, the tape is not torn) overlap several layers of the toilet, so that not open a slot.
bat-ngo-voi-meo-thong-tac-bon-cau-cuc-nhanh-chi-dung-bang-dinh-maxresdefault-3-1511160011-49-width600height337.jpg
Push the button, press the release button from 1 to 2 times to push the water up the adhesive tape. When the tape is inflated, press down on the tape several times with your hands.
bat-ngo-voi-meo-thong-tac-bon-cau-cuc-nhanh-chi-dung-bang-dinh-c--ch-th--ng-t---c-b---n-c---u-b---ng-b--ng-d--nh--1511160011-847-width600height337.jpg
High pressure from the top, plus water pressure to the point of clogging, clogged things will be cleared quickly.
Remember to use gloves and medical masks when preparing the toilet to ensure hygiene, open ventilation window. Before you take the toilet, just flush the toilet once the toilet has flushed out, you can not always make it obstructing the obstacles, but also increase the status quo.
Actually, I used to have a party trick like this.
I used clear cling film, same stuff you cover bowls with when you put them in the fridge.
I used to stretch it across the toilet bowl with no wrinkles in it.
Blokes and women half shot would use the toilet and end up getting pee everywhere and all over themselves.
Reply to Surprisingly, with the fast toilet switch, only the tape is used in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
