Discuss Suspected leaking pipe in concrete floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jock Spanners
Dear All,
I need a second opinion. I have a customer with an engineered oak floor which keeps discolouring apparently from damp below. The floor is in the corner of a cloakroom and near to central heating pipes. When the floor is lifted it does not appear to be soaking wet. I suspect a pinhole is feeding moisture into the concrete which is rising and finding itself trapped below the oak. When the floor is up it is simply evaporating. What is the easiest solution - did up the concrete and replace the pipes?
If it's not a major issue, bolster the floor (neat square) and have a look. It can always be made good and that way you'll expose the pipes and be able to either repair or rule them out.
Dear All,
Up the pressure temporary to make the pinhole show itself..
beware ...often these leaks go around in gangs due to dodgy work or poor stuff. Make sure your contract does not leave you holding the baby. big disclaimer ....centralheatking
Dear All,
As Rob has said - if it’s a sealed system up the pressure to try and make the leak show itself. Have you checked the condition of the external walls? It could be rising damp, or penetration from outside.
My experience of leaks in screed is there is always some evidence of it. It could be rising damp if there is no dpm under the concrete/screed. Is there a vapour barrier between the wooden floor and the screed?
Thanks guys. It's probably a 1930's house. The floor backs onto an internal wall. The affected area is around the flow pipe to a radiator fed from a combi. It's strange that it doesn't appear damp with the floor up but and soon as we put it back down the problem comes back. If she hadn't spent a fortune on an engineered oak floor I'll tell her to stick some vinyl down and forget about it. She's been a good customer but the job strikes me as being a potential can of worms nightmare.
Reply to Suspected leaking pipe in concrete floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
