Discuss Swapping joist in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Millsy 82
I went out to a toilet today and the customer said you might need to change the floor board as well as it has got a bit wet.
Well that was the understatement of the century I stood on the floor and it sank by about 2". So I ripped the floor up and had a look and the 1 joist has started rotting, so I said you need to get that replaced before I can do anything.
She has then asked me if I can do it. I said I've never done one before but will have a look.
It's only a short joist about 5 ft long and looks like it's been bodged before ( a massive great hole either end not patched up and a bit of 2x2 between the affected one and the joists either side) should it just be a case of cut old out and slide new ones in the holes and then patch up around it?
Replacing joists is easy, I've done a hole house, repairing parts and replacing entire floors,
Cut the old joist out and then slide the new one in (tantalised is best) but you may have to open one end up buy making the hole bigger above the original hole to get the joist in, then use slate to pack the joist level and sand&cement in place, then noggin between for extra support
That or you can use a big heavy duty joist hanger at one end but its best if you can avoid that if possible
That's the only one I took of the joist itself
I want to try and avoid that if I can help it.
You can always cut the joist so that is the size of the gap +one hole should be 4" roughly, then put a joist hanger either end and slide the joist so that its lapping into both holes by the same amount plus the just hanger to give you a full 4" support
not even rotten, most of the ones I have replaced are where the loo is sitting at a 45 degree angle :)
Reply to Swapping joist in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
