Discuss Switched live on Viessmann vitodens 100 boiler in the USA area at PlumbersForums.net
Hi all,
I have installed Viessmann vitodense 100 combi boiler and about to connect to my wiring center, I could not find to which connector/port on the boiler should I wire switch live. Has anyone experience with this?
any chance you could take a pic of the boiler wiring ?
Unfortunately not now, I don’t have access to the site now, the issue is I cannot find where to connect Lr and Ls on the boiler, even the representative is not sure for 100% !
I found from manual it can be connected to room stat connector (where Viessmann considers to connect Vitotrol), my wiring center (heatmiser UH4) gives Ls, Lr output for switching on/off the boiler, shall I connect both?
So L From the Viessmann goes to Ls on the heatmiser
Lr From heatmiser goes to L1 on the Viessmann
From the manual it looks like the boiler is designed to have the thermostats and valves wired directly into it empathetic than using a wiring centre.
i think so, but not 100% sure, the output of the wiring center is a volt free, so it is quite similar to thermostat output signal, but since I am not sure i am looking for more concrete schema,
Did you get sorted with your wiring? I am installing a uh8 to a viessmann 111w combi and have the same issue. Would be great to know if you found a soloution
Reply to Switched live on Viessmann vitodens 100 boiler in the USA area at PlumbersForums.net
hello! while saving up for a new plumbing and heating installation for my new one bedroom flat, i did a lot of research on different boilers and...
4K
Hello I have a NEST with Viessmann system boiler with unvented cylinder. I have a mid position and two position valve I thought the mid...
Hello, I am about to get the attached Viessmann 100-w heat only boiler with pump and diverter valve. Current boiler - Non Condensing System - OV...
Hi all, I had a new Viessmann Vitodens 100-w boiler (the new version) installed last year. The guy who was installing and commissioning it had...
5K
Morning all Viessmann Vitodens 200-W 35kW combi Outside temp sensor probably failed with boiler reporting incorrect temps. Corrosion on...
2K
