Discuss Tap gland in the USA area at PlumbersForums.net
Hi, trying to change the tap glands on my bath taps and I’ve undone the gland easy enough but it won’t pull out of the tap I put it all back together as I didn’t want to force it, does the other hex part of the tap have to be unthreaded as it looks like an extra flange, thanks
Do you know if they’re compression type (sounds like it) or quarter turn?
Hi, they’re compression type on some old bath tap’s, not sure if I should spray some silicone spray or something and pull again.?
It’ll just be the rubber washer stopping it, just pull a little harder and then remove the remnants of the washer.
I’ll try again another day, I didn’t know if it was something to do with what looks like maybe an adaptor to go from 3/4 to 1/2 as you can see another hex nut in the picture but I wouldn’t of thought that would be stopping it coming out.
Reply to Tap gland in the USA area at PlumbersForums.net
Hi guys. Very specific question... Got a RAS-C2 where the pin will only move a fraction of a mil and no amount of the usual tapping/WD40 will...
2K
Does anyone have any ideas how to get to the seat washer on this tap that is leaking badly at the spout. I'm assuming the gland part unscrews...
2K
I have a gate valve that shuts water off to outside hose bib, and it leaks through the valve stem when open. The valve was installed 25 years ago...
3K
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
