Discuss Victorian Tap head removal in the USA area at PlumbersForums.net
Does anyone have any ideas how to get to the seat washer on this tap that is leaking badly at the spout. I'm assuming the gland part unscrews from the spout but I've tried this with condserable force but with no luck. I'm assuming the spindle is secured in and does not pull out.
Any guidance would be much appreciated, thanks
Try GENTLY warming the body and the innards should unscrew using the flats. Hold the body so it doesn't turn. I normally wrap something around it so as not to mark it.
You're going anti-clockwise as you look down on it.
Your gland packing 'nut' has already been removed entirely, hence the serious leak. The spindle will come out if you get the valve body off (as Last Plumber has suggested) as the spindle will remove from the bottom end. Tip: a decent ring spanner (Whitworth/BSF) may be handy here, as well as careful use of a flame). But if you can't find a replacement gland packing nut, you may as well give up on that tap.
Wrap a cloth over the spout and lie the tap down on a hard floor surface (might dent wood if it’s tight) - lie it with the spindle to the right.
Use a tight fitting ring spanner and push this towards the floor - if necessary extend the spanner length with a pipe or by hooking another ring spanner over the open jaw end of the one you are using (easier to use a steel pipe).
Reply to Victorian Tap head removal in the USA area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
