Discuss Tap Spindle too Short in the USA area at PlumbersForums.net
I have recently brought new mondella pin lever 1/4 turn ceramic taps - Mondella Black Resonance Pin Lever Wall Top Assembly - https://www.bunnings.com.au/mondella-black-resonance-pin-lever-wall-top-assembly_p5004187
However once installed we don't have enough spindle left to properly attach the cover plate, tap handle and secure the screw so that the tap handle doesn't fall off we are only maybe 2/3mm off it working (the handle can be attached without the cover plate).
We tried to use these spindle extenders but they don't reach to the seat at the back of the tap, so the water constantly flows. Kinetic 28mm Ceramic Disc Spindle Extender - 2 Pack - https://www.bunnings.com.au/kinetic-28mm-ceramic-disc-spindle-extender-2-pack_p5050142
Does anyone have any ideas of what we could use? I cant find any spindle extenders or longer spindles that are the correct style for these taps.
I need these but in a different style? Kinetic 20 - 25mm Spindle Top Extender - 4 Pack - https://www.bunnings.com.au/kinetic-20-25mm-spindle-top-extender-4-pack_p5050144
Reply to Tap Spindle too Short in the USA area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
