TDS monitor
View the thread, titled "TDS monitor" which is posted in UK Plumbers Forums on UK Plumbers Forums.
finchy01
Morning all. My company have recently started using a TDS monitor when we flush. I u derstand how it works and what we're aiming for but I'm not sure what I'm actually monitoring! Can someone tell me as it would American explaining get to the customer a lot more professional if I actually know what I'm showing them!!!
The TDS (Total Dissolved Solids) meter measures the electrical conductivity of water. In its purest form, water is not a particularly good conductor of electricity. However, when other chemicals, many of which are conductors of electricity, get dissolved in water, its electrical conductivity goes up. Measuring the increased conductivity provides an estimate of the total dissolved solids in the water.
A good approach to using a TDS meter is to take a reading of the water from the kitchen tap, and then one from the water you are measuring. If the readings are within 10% of each other, then the test sample is reasonably free of dissolved solids in relation to the cleanest water available at the property. This is only applicable if the water is from normal mains, and does not apply to well / bore supplies.
Knew about the actual test process/measurementso etc but that 1st paragraph is spot on. No more replies needed! Many thanks.
Reply to the thread, titled "TDS monitor" which is posted in UK Plumbers Forums on Plumbers Forums.
finchy01,
finchy01,
