Discuss Test results in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sanke
Hi all Had a call tonight from a project manager for a building firm I sub contract to. A boiler has been moved at a clients house which has subsequently had a gas leak (blue flames from below boiler) NB I haven't been to this site at all & as yet we are uncertain as to who moved it !! When I have assisted an GSR to install a new boiler a gas tightness check has always been done before commencement of any work & then after. Is this correct practice or just his way of doing things ? Is there any set procedure to record the findings either for engineers record or to give to client ? I understand of this is not for general publication so if so I would be grateful if someone could pm me
if you prove your gsr you could post in the private section
We always carry out a Letby and Tightness test before any work is done on gas appliances
LP, I doubt he is GSR? His OP states when he has assisted a GSR engineer to fit a boiler ....
We generally only make mention of it when it does not pass if it passes we simply carry out the work, not give a report on the tightness test.
Thanks for the replies. LP I am not GSR but am seriously considering it. I have done the wet plumbing for several boiler exchanges so have observed how the GSR does things. As always keen to learn good practice
Reply to Test results in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
