Discuss Testing a capacitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bunker
Can anyone advise me how to do this? Strangely Ive not replaced one before (plenty of motors). I know the microfarads rating is on the side of it but, and please excuse the question....wth is a farad? I know you test it on resistance but whats the procedure please?
Fank ooo.
You need to de energise it by putting a long screwdriver across it to a earth point. if you don't de energise it you could get a serious shock.
First discharge it as Rob has stated
Then put your multimeter across the pins setting it in the high ohm range 10k-1m
Should start at zero and then move toward infinity, if it doesn't the capacitor is knackered.
Reply to Testing a capacitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
