Discuss thermostatic valves on wrong side of rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
peter wilson
Hello i noticed some of my rads heat up on the return side first. This would mean some have the therostatic valves on the wrong side.
Not aprob when all fully open but how do i balance the rads as you normaly do it from the lockshield side.
Hi Simon thanks for your reply, so if i balance the rad from lock shield side even though the flow on that rad is comeing in from that side, thats still ok?
Therm valves can be fitted on any side. Balancing can be done on any side that is lock shield. It is only to slow the flow, so any pipe does.
Thanks for the replys, yes they are two way trvs and the arrow is pointing in the flow direction.
Now i can go fishing tomorrow instead of pluming.
Reply to thermostatic valves on wrong side of rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
the majority of my radiators have thermostatic valves. Some of these work fine but some of them dont let you adjust the temp. ie. Setting one or setting 5 makes no difference - the radiator is blazing hot. For small bedrooms this is pain cos the room just heats up too much. we first...
I have a heating system comprised of skirting radiators that form part of a loop from the boiler, round the house and back. Some rooms get warmer than others despite closing off the skirting radiator heat vent. They are designed to house the finned heating pipe and a return pipe, the latter...
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was working fine for a coupe of months however now the valve has started misbehaving which is resulting in having to turn the temperature valve round further...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate tank. There is a thermostat on this second tank that pushes hot water over to the store tank when it's hot. It's a closed loop and goes through a heat...
