Discuss This gate valve position.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Excuse my wonderful drawing.
Someone put a gate valve here. If I've used the wrong symbol for a valve forgive me you'll have to imagine the right one.
There isn't one anywhere on the cold feed from the CWSC.
Since - if closed this isolates the water in the cylinder from the open vent - my guess is it is against regs as hot water has nowhere to expand.
However my question is....As long as the water is cold/hot water turned off can I use it to isolate the hot just to change a tap?
Not seen one in this position before and don't won't to overlook something. Can't think of a reason why that wouldn't be ok but want to check
Also, bonus question. If the hot water was off but still had say a bit more cooling to do before it reached where it was going to stay - and this valve was closed - would this cause any issues?
If it's dodgy to use I'll just drain the CWSC, fit one on the cold feed.
Thanks all. Did the tap and took off the handle and advised the customer.
Out of curiosity though any thoughts about my other question in the OP?
"If the hot water was off but still had a bit more cooling to do before it reached where it was going to stay - and this valve was closed - would this cause any issues?"
If hot water expands then surely it's going to contract when it cools and if the vent is blocked could this in a worst case scenario bring about the same risk of cylinder implosion you can get from opening a tap if the vent is submerged?
Reply to This gate valve position.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to...
