Discuss Tigerloop has no oil. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sparkybob
Hi, i'm new to this forum and am looking for a bit of advice, I've just moved into a new house and the level of oil in the tank was quite low (below 1/4) i tried to start the boiler and it fired and ran, worked fine, switched it off again, left for about a month and tried to fire it up again, wouldnt go, assumed oil level was too low. Today i had oil delivered and tried to start the boiler but no success, it seems that there is no oil getting to the tigerloop, all valves are open, but no oil is being drawn up from the tank, is there a way to bleed the tigerloop?
Thanks in advance
Bobby
Sadly not lol and id say its about.....20-25 feet? then verticly for about 3-4 feet
just took a rough measurement, 30ft in total and yup 10mm pipe covered in white plastic
You will need to gdt an engineer in with the right pump to suck the oil up from the tank via tiger loop. If you didnt have the pump I would connect a short piece of 10 mm pipe to the inlet to tiger loop place the open end into a bottle containing kerosene start the boiler snd it will primethe tiger loop. Replace oil lind and the primed tiger loop should pull the oil up. The check valve in the tiger loop may have gone hence advise to get an engineer in.
I've phoned the landlord and told him so he's getting someone tomorrow just wondered if there was something i could do to save the guy coming
Ummmmm. Just like a petrol filled transit...... Leaves a bad taste in your mouth!
I had a customer who tried priming his boiler by sucking the flexy he got a mouth full of kerosene 4 or 5 times I said mate ur going to be ill I'll fix this he kept saying save me some cash Then he got a full mouth full and he was properly ill went to hospital I used my priming pump 1 min all working. Money please
Filled van with petrol once, tried to syphon, went home like a buckled wheel!
Reply to Tigerloop has no oil. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
