Discuss To cross bond or not? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've had a new boiler installed in one of my buy to lets and the tenant called up after a few months to say they were getting a slight shock through an adjacent tap. My electrician said that this was due to the boiler not being earthed/cross bonded. The guy who installed the boiler said this wasn't a legal requirement and doesn't make a difference and couldn't be the cause. The electrician insists that if copper pipes are used, this is a requirement. I'm keen to know who's right. Any thoughts?
Not required any more as far as I know
Gas should be earthed at the meter and mains cold at the stop tap
I’m not an electrician, but if the system is a PME as most are. Then all exposed metallic pipes will need connecting to the CPC.
A simply resistance test with a multi-meter will prove it.
Any ideas on how many rcds on consumer unit? Should have x2 if 17th edition. As JC plumb stated, earlier still requires cross bonding etc.
Water and gas should be main equipotential earth bonded regardless of wiring edition.
There is clearly *an* earthing/wiring problem with the property. I suspect you'll find there is a lack of earth continuity somewhere. If so, cross-bonding the boiler may mask the problem but won't fix the root cause.
I think you want someone with a broader-remit than than just the boiler. My vote is that you should get the electrician to check the earthing of the entire dwelling starting at the consumer unit.
Thanks all. The electrical box was replaced at the same time as the boiler so will be a current edition. Sounds like it isn't a boiler related issue after all and checking the earthing of the whole house is the way forward
Judging by this I have found may still not be current edition, but does state that earth bonding arrangements are adequate. Did you receive an electrical condition report and were you issued a certificate?
If your tennant is reporting an electrical shock issue, then if it was one of my properties I would be round there directly stuff which edition the consumer unit is Rob Foster
aka centralheatking
True. :confused: Sometimes you can get too engrossed in legislation and miss the whole point :eek:
Reply to To cross bond or not? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
we had a grant condensing boiler fitted last year, the lad works for a heating company and said would fit it. when he did he put the pipes all...
Not sure what my options are here. Basically a friend of mine recommended his father in law to do our plumbing/gas work for our renovation. First...
2K
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
About 10 months I started having issues with a gas like smell in my home and the gas board was unable to find any gas leak I've still got the...
