Discuss Toilet cover surround in the USA area at PlumbersForums.net
I have just been cleaning and noticed our upstairs toilet has a surround that goes over the exit of the toilet through the wall.. this surround I believe should sit flush and sealed to the wall?? Is this an urgent repair?
Just a cover to hide an ugly hole, can buy round plastic ones or some are homemade. Not urgent but may be letting a draft of cold air through if it is an external wall. Some are screwed to the wall others are just pushed against or stuck with silicone. Depending on room it is an easy diy job.
This is a cheap one.
Slightly more money.
Reply to Toilet cover surround in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
