Discuss Toilet keep blocking - suspected problem with WC connector. in the USA area at PlumbersForums.net
I have a problem. We've just had a toilet fitted and its already blocking up. We can clear the blockages with a lot of plunging but it doesn't take much to block it back up. Also the flow rate of the flush seems lacklustre even when not blocked - it doesn't seem strong enough to pull the paper down in one flush.
The TLDR: IS the excess outlet pipe in the 90 degree connector restricting the flow and can I just disassemble it and cut off the excess to increase the flow and stop the blockages.
N.B calling the plumber back is not an option. This is one of about 5-10 problems and we don't want the guy anywhere near this house again.
Any help here would be greatly appreciated. I'm not familiar in any way with plumbing, but this is what I think is happening...
I believe the plumber has used 2 pan connectors fixed together to span the horizontal distance between the existing soil pipe and the toilet spigot. Maybe this is standard practice (i don't know). Now by looking in the boss I can see the outlet of the first connector coming too far into the second connector (which is a right-angle) and that is reducing flow and causing blockages.
MORE PICTURES IN ATTACHED PDF.
Thanks in advance
  • Toilet.pdf
Only certain pan connectors are trimmable. But definitely being restricted by that other pan connector pushing into other one. Extend soil pipe and 90 bend in soil pipe and pan connector into that strap on boss for smaller pipe. Or you could tee for the toilet and put what I assume is basin waste into tee via adapter.
Well I can see why you don`t want the muppet back! Wrong horizontal fitting used and basically blocking the exit point.
My McAlpine book is in the van but pretty sure that they will have the first and correct fitting you need.
Reply to Toilet keep blocking - suspected problem with WC connector. in the USA area at PlumbersForums.net
Suddenly my downstairs toilet stopped filling this week, I suspected a blockage in the filter or cistern itself, however after removal of...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
Hi all, We've got a toilet that's been leaking due to a faulty seal with the pan connector. We've had a plumber in to replace the pan connector...
Hello All, We recently had a plumber out to replace a pan connector as the previous set up had developed a leak, however, following the...
2K
R
One of my toilets has air bubbles coming up every once in a while. Sometimes the toilet fills up to the top and goes down slowly. It seems to...
