Discuss Toilet keeps running? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
This toilet is constantly running water into the bowl. Am I right in having to remove the valve on the right & change the washer? The one on the left I can see the water keeps coming out of.
Yes the centre / one on the right when standing in front should twist 1/4 and you will find the washer has bubbled
If you use a torch to shine down the side of the valve you will see which way to twist as you will see the clips
How do I get the thing out? I've tried turning every point I can & pulling but it just seems stuck in there. It only turns so far as you can see it's tight in there & I can't turn it anymore either way as the cistern stops it being able to.
The centre round one your turning ?
Reply to Toilet keeps running? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
