Discuss toilet leak from pvc pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
hi i have a drip leak from the bottom of this pipe
see attached how do i fix it is there a video
that would help me
cheers
The only chance you have of a quick fix is to try and tap the outer ring back over the rubber connector.
Tap the outer plastic ring away from the pan.
If that doesn't fix it, plan b is to remove pan and put a new connector on.
Problem with that is you have a skew pan - pan outlet to the left.
If you break the pan removing it, an new skew pan will cost you @ $400.00.
They are expensive for the reason that only 1 company makes them and if you need one, you will pay the price.
Reply to toilet leak from pvc pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
