Discuss Toilet service valve leaking not cross threaded in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a toilet service valve that is leaking as it tightens on to the toilet fill valve. It is not cross threaded hand tightens with ease a good few turns, I have tired replacing the fiber washer to no luck. I have also tried ptfe with no luck. Any idea what could be happening, as I said it is not cross threaded.
is there a gap between the fibre and plastic when seated?
In my experience the fibre washers u get nowadays are terrible and I hate using them. Get a flexible tap connecter ( compression ) which has a rubber washer . There only couple quid.
http://m.NoLinkingToThis/p/flexible-hose-with-valve/34083
I don't think so, there is alot of play on the pipe. I have tired doubling up the washer and this made no difference either
Sometimes the plastic threads crack. You would be best replacing the balvalve with a metal shank, like fluid master.
replace with flexi or hand tighten speedfit swivel and ballafix.
oh and dont forget to check its not leaking from the actual service valve, sometimes they need a tighten up.
The service valve opposed to an isolating valve has the short length of pipe between the valve body and the nut with the washer, I`ve had these leak from there before.
Not so long ago there would of been an out cry on here if you told somebody to fit a flexi. lol
Reply to Toilet service valve leaking not cross threaded in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
PSxxxxxx
